Before running any Intel AMT command on the Intel AMT asset, you need to configure the Intel AMT asset. Configuring the Intel AMT asset requires you to provision it from the DSM domain manager so that the asset is ready to run the Intel AMT commands.
Note: If you do not provision the asset from the DSM domain manager, the asset will not run any Intel AMT command.
A provisioning toolkit is installed with the DSM domain manager in C:\Program Files\CA\SC\ConstantAccess\caprovision.exe. Use the caprovision.exe file from the DSM domain manager to provision the Intel AMT asset.
