Customizing Asset Management › CA Asset Converter for Microsoft SCCM › Task Properties › Task Management › Run a Task
Run a Task
Once the task has been created and configured, it must then be linked to an engine in order to be run.
To run a CA Asset Converter for Microsoft SCCM task
There are several ways of doing this:
- Drag and drop the SCCM task onto the appropriate engine in the tree view of the DSM Explorer.
- Navigate to the engine in the tree view and click Link Existing Task in the information pane. Then select the CA Asset Converter for Microsoft SCCM task in the dialog that appears.
- Navigate to the engine in the tree view and click Add New Task. The Create New Task wizard appears, allowing the creation, configuration, and linking of the task all to be accomplished in one step.
Once linked, the engine will perform the task the next time it comes up in its task list and the scheduling configuration allows it to be run.
