You can test the Chassis inventory module manually and verify that the correct information has been collected.
Note: Running the inventory collection module manually is for testing or diagnostic purposes. In some situations, diagnostic messages are displayed on the screen, which does not affect the inventory collection and is not harmful.
To test the Chassis inventory module manually
cd $CA_ITRM_BASEDIR/Agent/AM/plugin
./amvminvhp 0
The Chassis inventory is written to the following location:
$CA_ITRM_BASEDIR/Agent/AM/data/transfer_vm/amvminvux.inv
After the Chassis inventory file is created, you can manually run the AM remote agent using one of the following methods:
./amVMAgent register
caf start amagent
Note: Starting the amagent will automatically start the AM remote agent and the registration process.
