You must install the AM remote agent on every nPar and vPar to collect and report the inventory information. This installation does not require the configuration of the virtual host inventory collect task.
Note: It is recommended that you install the agent on every nPar and vPar only if you have sufficient resources available on the nPar and vPar systems.
