Previous Topic: Inventory File FormatNext Topic: Hardware Section
General Section
The general section contains the entries for the inventory item. The items allowed in the header section are determined by the type of item being described. Some header item should only be provided in an <asset> <general> section, others only in <user> <general> sections. There are also some attributes that can be provided in either a user or asset general section.
A user can be delivered alone or with a computer. If a user is delivered with a computer, the user is linked to the computer. This relationship is visible in the DSM Explorer.
The following table lists the general section tags:
Name
Description
Header
vendor
string optional
asset
serial_number
string optional
asset
asset_tag
string optional
asset
host_name
not fully qualified, required
asset
host_key
string optional key will be generated if not supplied
asset
class_id
Platform name as a string or a number
Note: See the detailed list of platform names in the "Platform Names and IDs" appendix.
asset
Network_id
Optional
Note: Supports multiple network interfaces in the registration section of the XIU file.
asset
default_address
required
asset
default_mac
required
asset
default_hostname
required
asset
default_subnet_mask
optional
asset
collect_time
time in seconds, optional
asset
trustlevel
integer between 1 and 5, optional
asset
origin
string optional
asset
fileid
Max length 36
user
URI
required
user
user_name
required
user
domain_name
N/A
user
previous_uri
N/A
user
r_usage_list
N/A
user
r_name
N/A
user
r_proc_os_id
N/A
user
r_ip_address
N/A
user
user_item_1
N/A
common
user_item_2
N/A
common
user_item_3
N/A
common
user_item_4
N/A
common
r_computer
N/A
common
collect_time
N/A
common
trustlevel
Int 1 to 5
common
origin
String 64 char max
common
Note: If the MAC address is not available, you can specify the UUID of the asset.
Example: User Only
The format for a user only in the file is as follows:
<asset>
<user>
<general>     </general>
<hardware>    </hardware>
<software>    </software>
</user>
</asset>
The hardware and software section are optional in both the asset and user sections of the file.
Example: User and Asset
The format for a user delivered with an asset is as follows:
<asset>
<user>
<hardware></hardware>
</user>
</asset>
Example: General section
The following is a code example for the General Section.
<?xml version="1.0" encoding="utf-8" ?>
<asset translator="ACBsFmt" version="1_0">
<general>
<host_name>machine1</host_name>
<default_hostname>machine1.domain.com</default_hostname>
<default_address>150.120.13.119</default_address>
<default_mac>00:0D:56:CB:C1:ED</default_mac>
<class_id>21</class_id>
<network_id>
		<mac_address>mac</mac_address>
		<ip_address>ip</ip_address>
		<dns_name>name</dns_name>
		<subnet_mask></subnet_mask>
	</network_id>
<host_key>70669be2-1fed-4201-9777-d7137486dcab</host_key>
<origin>User Keyed</origin>
</general>
</asset>
Note: Default_hostname, default_address, default_subnet_mask are the required entries. The network_id section is optional. You can include multiple network_id sections. The default_hostname, default_subnet_mask, default_mac, are used in the default_XXX fields, in the common_asset_report. Additional network_id sections are populated into the registration message.
The following illustration shows how the general section inventory looks when viewed in the DSM Explorer.
Screenshot providing information about assets on the network having a DSM agent that connects to the domain
In the preceding illustration, note the following:
