Previous Topic: Why Do I Get Duplicate Agent Names?Next Topic: Unable to Locate Log File
How Can I Display the Agent Bridge Log Files?
Symptom:
I cannot see the log files for the Agent Bridge components in the ..DSM\logs directory. How can I display these log files?
Solution:
After you run the command line script, AgentBridge.dms, you should restart the CAF service to ensure that all trace file entries are registered properly to the system. If after starting CAF, you still cannot see the Agent Bridge log files, contact CA Support Online at http://support.ca.com for further assistance.
