Previous Topic: User Defined GroupNext Topic: Add New Groups
Types and Subtypes
The following table includes the valid types and subtypes that you can specify for the attributes:
Note: The subtypes determine how a value is displayed in the GUI.
Type
Subtype
Description
Boolean
Boolean values can be displayed based on the following subtypes:
TrueFalse
True or False
YesNo
Yes or No
OnOff
On or Off
SupportedUnsupported
Supported or Not Supported
ActiveNotactive
Active or Not Active
OkError
OK or Error
PresentNotpresent
Present or Not Present
int32 & int64
Numerical values can be displayed based on the following subtypes:
separation
Thousands separated, that is, 1,000,000
normal
No separation
K
Number is divided by 1024 before display
M
Number is divided by 1024^2 before display
G
Number is divided by 1024^3 before display
T
Number is divided by 1024^4 before display
kilo
Divided by 1000 before display
mega
Divided by 1e6 before display
giga
Divided by 1e9 before display
milli
Multiplied by 1e3 before display
micro
Multiplied by 1e6 before display
nano
Multiplied by 1e9 before display
hex
Numbers shown as hex
time
Displayed as a date-time
timeInterval
Displayed as a duration
bytes
GUI decides to display as KB, MB, GB or TB
Float
Float values can be displayed based on the following subtypes:
Auto
Auto format
placesXX
Show to XX decimal places
String
No subtypes for string
