You can categorize your software definitions and organize them for easy retrieval based on the definition types, manufacturer, and category.
To organize products by categories
The existing categories are displayed in the right pane.
The New Software Category dialog appears.
Note: You can also use the existing categories.
A new category is added.
The Organize Category dialog appears.
The selected definitions are added to the category.
