Configuring Asset Management › Custom Software Signatures › How to Create Custom Software Signatures › Create a Suite Component
A suite component is an individual product in the suite such as Microsoft Word. To get the suite component level inventory, you need to create and add the suite components to the suites.
To create a new suite component
- Navigate to the Domain, Software, Definitions, Categories folder in the DSM Explorer.
The existing categories in the domain appear.
- Select an existing category or create a new one by clicking New Category in the Tasks section.
The existing definitions in the category appear.
- Double-click the product.
The existing releases and suites in the product are displayed.
- Right-click the suite to which you want to add the suite component and select New Suite Component.
The Create New Suite Component dialog appears.
- Specify the details of the new component in the General, Recognition, and Exclude Options tabs and click OK.
A new suite component is created under the suite.
More information:
