The content utility generates a set of log files from which you can determine the status or result of the export or import. The following log files are located under ...\DSM\logs:
Contains the information generated by the content utility since the time it started.
Contains the actions performed on the host system.
Contains the information generated during import that is overwritten with the last import data. These files are available in the data directory for each processed table.
