Previous Topic: Heuristic Scanning for Virtual ApplicationsNext Topic: Run the Content Utility
Content Utility
The Content Utility tool lets you share software definitions between independent CA ITCM installations. The new and updated software definitions provided by CA Technologies are first downloaded to an online domain (or enterprise) manager that has access to the Internet, and then can be imported into all the offline domain (or enterprise) managers.
The exported definitions are saved as text files that can be shared by installations that are either not part of the same network or run in an offline environment.
You can export the software definitions to files on a shared network location or a portable media, such as a USB device, and then import them into the offline installations.
The utility works with both CA Technologies provided and custom-created software definitions and is available as a command line utility.
Important! This utility is currently supported with SQL and Oracle databases and can run on or later releases of CA ITCM Release 12.8 manager systems. You can export and import the contents from/to CA ITCM managers Release 12.8 Release or later.
