The following table lists the new fields added to different nodes of the inventory:
Inventory Node |
Field |
Description |
General Inventory, Power Settings, Power Policy |
AC - Processor Throttle DC - Processor Throttle |
CPU throttling or processor throttling is the process when the CPU attempts to prevent damage due to overheating. If the CPU temperature exceeds the specified limits, the system throttles down the CPU for cool down. This process takes place when the computer is idle or when no critical tasks are executed on it. The CPU switches to a lower frequency for optimal consumption of energy and to ensure minimal noise from the fans. |
General Inventory, Power Settings, Power Usage Times |
Total Log Time Off Time Off Time % On Time On Time % Suspend Time Suspend Time % Verify Time |
These fields comprise data that various Inventory Detection and Collection modules collect. Total Log Time: Specifies the total time duration over which analysis is performed. It is allowed for the last 30 days or the duration since the last CA ITCM installation, whichever is less. Suspend Time: Includes the sleep and hibernate times. Verify Time: Specifies the actual time that is considered for the analysis. It is the sum of On Time, Off time, and Suspend time. |
General Inventory, Power Settings, System Sleep States |
CA ITCM supports multiple sleep modes that correspond to the power states defined in the Advanced Configuration and Power Interface (ACPI) specification. |
General Inventory, Power Settings, System Wake Armed Devices |
Devices that are currently configured by the user to wake a computer from any sleep mode. |
General Inventory, Power Settings, System Wake Programmable Devices |
Devices that a user can configure to wake a computer from a sleep mode. |
