Use the Add the Virtualization Server to the configure dialog to select a virtualization server type and add one or more virtualization servers.
Note: Required fields are listed in the table that follows this procedure.
Specifies the Web Service password of the specified user.
Note: Regarding passwords and SSH keys, only one or the other is required for authentication. We recommend using SSH keys because they are more secure than plain text passwords.
(IBM HMC) Specifies the host serial number.
Specifies the URL of the Web Service.
The URL takes the following form:
https://ESXHostFQDNservername/sdk
https://XenMasterFQDNservername
The variable in each instance represents the fully qualified host name of the server. Alternatively, an IP address can be given instead of the host name.
The default behavior for this field is for it to be auto-populated unless the RVI Edit URL configuration policy has been changed. For more information about this policy, see Asset Management (Administration Console) Policy Group.
Specifies the location of the Secure Shell (SSH) *private* key. Provide an SSH key location for a Linux/UNIX host only if the key is not in the default location.
Note: An empty passphrase must be provided when generating the SSH key.
You are returned to the Virtualization Servers tab page.
The new virtual host inventory collect task is added to the Collect Tasks folder.
The following table indicates which fields are required based on the specified virtualization server type and the OS type of the agent computer:
Target/Remote Agent Host |
Windows Agent Host |
Linux/UNIX Agent Host |
HP Integrity Virtual Host |
Password or SSH key location |
(Optional) SSH key location |
IBM Hardware Management Console (HMC) |
Host Serial Password or SSH key location |
Host Serial (Optional) SSH key location |
Sun System Controller |
VMware vSphere Hypervisor (ESX, ESXi) |
Password Web Service URL |
VMware vCenter Server |
Citrix XenServer |
Microsoft Hyper-V |
Password |
Host Name |
