Use the Virtualization Servers tab page to add, remove, and view the properties of virtualization servers you want to configure for remote inventory collection.
To add a virtualization server to the collect task
The Add the Virtualization Server to Configure dialog appears.
Note: You can add up to five virtualization servers per collect task. If the same agent must collect data from more than five virtualization servers, you can define additional collect tasks for the same agent.
You are returned to the Virtualization Servers tab page.
You are returned to the Select New Collect Task type dialog.
The RVI configuration information is transferred to the specified agent computer at the next scheduled runtime.
