The online utilization data is stored in the file system of the scalability server for a maximum of three days only. If you want this data for future reports, you can import the data from the scalability server and export it to the database.
To import online utilization data into the database
The Offline Utilization window appears.
The Online Utilization window appears.
Note: The Import to DB option is available only if you are in the Online Utilization window.
The online utilization data in the scalability server is imported and saved in the database.
