Previous Topic: Enable Usage MonitoringNext Topic: Full Utilization Data
Software Usage Components
The software usage feature uses the following components:
Software Usage Server
The software usage server resides on the scalability server. It performs the following functions:
Note: The software usage server can distinguish different versions of the same application, for example, Microsoft Word 97 and Microsoft Word 2000.
Software Usage Agent
The software usage agent resides on all the assets managed by asset management and is started whenever the asset management agent starts.
Note: The software definitions must be unique. If you create two or more identical software definitions and configure the software usage agent to monitor them, only the first definition added to the software usage collect task is reported as started.
