Previous Topic: Run a ReportNext Topic: Import Report Templates
Export Report Templates
You can also export report templates from one domain to another domain in an enterprise to reuse the report templates.
To export reports from the selected folder (including sub folders)
  1. Right-click any folder under the Report Templates folder and select Export All Report Templates.
    The Export Report Template dialog appears.
  2. Specify the destination folder and select the Export templates from subfolders recursively checkbox and click OK.
    The report templates available in the selected folder and all its subfolders are exported to the destination folder.
Note: You can also export a particular report to a file, by right-clicking the report and selecting Export, Report Definition.
