Reporter preferences define the settings for administrators and all users. You can customize the reporter preferences to present the report the way you want it.
To specify reporter preferences
The Preferences window appears.
Defines whether you want to display the tips in the report's information pane or use old style message boxes. Tips are marked with a yellow bulb icon.
Defines the user's personal preferences regarding the appropriate actions to take place after running a report.
Defines the report viewing settings.
Specifies the number of auto-history result sets to be kept under Results in the Contents tree. Older results are deleted permanently from the database. With respect to the user interface, the administrator even may choose to delete folders that still contain files.
Specifies the number of scheduled results to be kept by default.
Specifies that only administrators can reset statistics and that only administrators can edit result count for scheduling.
Allows the deletion of non-empty folders, performance of a consistency check and so on.
Lets you include the domain name in the new and imported templates when the reporter runs in at the enterprise manager.
Note: For more information about the Preferences dialog, see the DSM Reporter Help.
