Configuring Asset Management › Collect Tasks › Software Usage › Software Usage Components › Software Usage Limitations
Software Usage for Windows is subject to the following limitations:
- No usage information for DOS-based applications.
- Unicode is not supported.
- Software usage is supported on Terminal Server Console sessions, but not over Terminal Services sessions. When several instances of an application are running simultaneously, software usage counts only the first instance of the application.
- Software usage running on a Terminal Server requires that the Terminal Services service is running.
