Symptom:
When I deploy the asset management agent on Windows XP SP2 computers, it results in delivery failure and shows the status as no primer transport.
Solution:
The local security policy and the firewall on the Windows XP SP2 computers prevent access to the system. Before deploying the asset management agent, you must change the local security policy and specify the firewall settings.
To change the local security policy
The Local Security Settings window appears.
The Local Security Policy is changed.
You must open the UDP ports for CAM communication, by changing the firewall settings.
To change the firewall settings
The Windows Firewall dialog appears.
