Template inventory modules let you collect customized inventory information from a MIF file; information which is not collected by any of the inventory detection modules. Asset management uses the following process to store and retrieve the information from the MIF files. By understanding these actions, you can choose how to best configure the MIF files as per your requirements:
Note: The agent processes only the .MIF files that fulfill the DMI specification.
