You can create and configure a template inventory collect task to collect the inventory information configured in the selected template detection modules.
To create and configure a template inventory collect task
The Select New Collect Task Type dialog appears.
The Schedule New Collect Task dialog appears.
The Scheduling Options dialog appears.
The Scheduling Options dialog closes and the Schedule new Collect Task dialog appears.
The template inventory collect task is saved with the above settings.
