Virtual hosts appear as normal nodes under All Computers along with all the other computers.
If you want to view only virtual hosts, you can create a custom computer query based on the class ID of the computer.
To view only virtual hosts
The Select Target dialog appears.
The Query Designer dialog appears.
The Select Field dialog appears.
Class |
Subclass |
Unclassified |
RTOS Sun RTOS |
Virtual Host Machine |
HP Chassis IBM Server |
Hypervisor |
VMware ESX |
VMware ESX Server 3.5 |
VMware ESX Server 4.0 |
Sun eXtended System Control Facility (XSCF) |
You are returned to the Query Designer.
The Save Query dialog appears.
The results are displayed under the All Computers pane.
Note: Since there is no agent component installed for virtual hosts, no jobs or configuration can be applied to them. Hence, the asset context menu is disabled.
