After a query is designed, you can run the query to view the results.
To run a query
The query is executed and the results are displayed in the Query Preview dialog.
Note: The query execution times out after every 5 minutes with a message that allows you to either continue or cancel the query execution. At any time during the execution, you can press the Esc key to cancel the execution.
Note: Queries submitted to the engine run automatically.
