Previous Topic: Run a QueryNext Topic: Save a Query Result
Preview a Query
You can preview the query results even while you are designing the query in the Query Designer dialog. This helps you to know if the query is producing the desired output. You can also view the SQL version of the query by clicking the View SQL icon.
To preview the query results in the Query Designer dialog, create a new query in the Query Designer dialog and click Preview in the left pane. The Query Preview dialog appears showing the results of the query.
Note: The query execution times out after every 5 minutes with a message that allows you to either continue or cancel the query execution. At any time during the execution, you can press the Esc key to cancel the execution.
If you want to view the results of a query that has been applied to a dynamic group or a policy, or if you want to query your domain for the latest information, you must complete the following:
Important! The Query Designer gives you both flexibility and responsibility. An erroneous query can cause the engine to crash. Always test the query using the Preview option before applying it to a dynamic group or a policy!
