Previous Topic: Customize LogicalsNext Topic: Tracing Error Callbacks
Assign CONSOLE DAEMON and CONSOLE CTRLs Quotas
For most situations, the process quotas for console processes are adequate. However, under conditions of very high stream of events, very large number of remote connections (100+), or a very high number of interface actions, the following console logicals can be set to improve performance. These values should only be used after consultation with CA. Use the following command to define these logicals:
$DEFINE /TABLE=CONSOLE$LOGICAL_NAMES logical_from_table
Logical
Function
Value
CONSOLE$DAEMON_ASTLM
Assign ASTLM quota
Recommended: 8192 (AXP) (Default 1024)
CONSOLE$DAEMON_BIOLM
Assign BIOLM quota
Recommended: 1000000 (AXP) (Default 1024)
CONSOLE$DAEMON_BYTLM
Assign BYTLM quota
Recommended: 1000000 (AXP) (Default 655350)
CONSOLE$DAEMON_CPULM
Assign CPULM quota
(Default 0)
CONSOLE$DAEMON_DIOLM
Assign DIOLM quota
Recommended: 100000 (AXP) (Default 1024)
CONSOLE$DAEMON_FILLM
Assign FILLM quota
Recommended: 2048 (AXP) (Default 1024)
CONSOLE$DAEMON_PGFLQUOTA
Assign PGFLQuota
Recommended: 1280000 (AXP) (Default 30000)
CONSOLE$DAEMON_PRCLM
Assign PRCLM quota
Recommended: 2048 (AXP) (Default 64)
CONSOLE$DAEMON_TQELM
Assign TQELM quota
CONSOLE$DAEMON_WSQUOTA
Assign WSQUOTA quota
Recommended: 32568 (AXP) (Default 2048)
CONSOLE$DAEMON_WSDEFAULT
Assign WSDEFAULT quota
Recommended: 16284 (AXP) (Default 512)
CONSOLE$DAEMON_ENQLM
Assign ENQLM quota
Recommended: 4096 (AXP) (Default 1024)
CONSOLE$DAEMON_WSEXTENT
Assign WSEXTENT quota
Recommended: 65136 (AXP) (Default 8192)
CONSOLE$DAEMON_JTQUOTA
Assign JTQUOTA quota
CONSOLE$PAUSE_BEFORE_
RECONFIG_MULTIPLE
Assign number of seconds
to wait before reconfiguration.
This is used in conjunction with the child controller ID to prevent reconfigurations of all controllers at the same time.
Reconfiguration of an individual controller is (idx value) seconds.
Use the following logicals to assign the initial size and extension size of the associated files. This is normally done when the user knows there will be a very high number of entries. This will help prevent the files from being extended multiple times, thereby reducing the efficiency of the system.
Logical
Function
CONSOLE$TIMES_INITIAL_
ALLOCATION
Assign initial allocation of the SYSTEM_NAME.TIMES files.
CONSOLE$TIMES_EXTENSION_
QUANTITY
Assign extension quantities to the SYSTEM_NAME.TIMES files.
CONSOLE$EVENTS_INITIAL_
ALLOCATION
Assign initial allocation of the SYSTEM_NAME.EVENTS files.
CONSOLE$EVENTS_EXTENSION_
QUANTITY
Assign extension quantities to the SYSTEM_NAME.EVENTS files.
CONSOLE$LOG_INITIAL_
ALLOCATION
Assign initial allocation of the SYSTEM_NAME.LOG files.
CONSOLE$LOG_EXTENSION_
QUANTITY
Assign extension quantities to the SYSTEM_NAME.LOG files.
Use these logicals when there is high burst events traffic to prevent loss of data.
Logical
Function
Value
CONSOLE$IPC_DATA_
MAILBOX_SIZE
Enables enlargement of the data mailbox
(Default 5 mailbox messages )
CONSOLE$IPC_MAILBOX_SIZE
Enables enlargement of the mailbox size
CONSOLE$IPC_CONNECT_
TIMEOUT
Assign the timeout value during the connection
(Default 30 sec)
CONSOLE$ENS_GC_INTERVAL
Assign the time interval to
clear out any old event records from our queued events and reset the entries for our running processes where appropriate
(Default 30 sec)
CONSOLE$BUFFER_FLUSH_INTERVAL
Assign the time interval for buffers' flushing
(Default 30 sec)
These values are used under conditions of high stream of events, very large number of remote connections, or many interface actions to the ENS process.
Logical
Function
Value
CONSOLE$NOTIFY_ASTLM
Assign ASTLM quota
Recommended: 1600
(Default 200)
CONSOLE$NOTIFY_BIOLM
Assign BIOLM quota
Recommended: 100000 (Default 1000)
CONSOLE$NOTIFY_BYTLM
Assign BYTLM quota
Recommended: 1000000 (Default 200000)
CONSOLE$NOTIFY_CPULM
Assign CPULM quota
Recommended: 0
(Default 0)
CONSOLE$NOTIFY_DIOLM
Assign DIOLM quota
Recommended: 20000 (Default 200)
CONSOLE$NOTIFY_FILLM
Assign FILLM quota
Recommended: 200
(Default 100)
CONSOLE$NOTIFY_PGFLQUOTA
Assign PGFLQUOTA
Recommended: 1280000 (Default 10000)
CONSOLE$NOTIFY_PRCLM
Assign PRCLM quota
Recommended:2048
(Default 20)
CONSOLE$NOTIFY_TQELM
Assign TQELM quota
Recommended: 4086
(Default 512)
CONSOLE$NOTIFY_WSQUOTA
Recommended: 4086
(Default 2000)
CONSOLE$NOTIFY_WSDEFAULT
Recommended: 10000 (Default 100)
CONSOLE$NOTIFY_ENQLM
Assign ENQLM quota
Recommended: 2096
(Default 500)
CONSOLE$NOTIFY_WSEXTENT
Recommended: 65136 (Default 5000)
CONSOLE$NOTIFY_JTQUOTA
Recommended: 4096
(Default 1024)
