Previous Topic: Console Manager TuningNext Topic: Assign CONSOLE DAEMON and CONSOLE CTRLs Quotas
Customize Logicals
The following logicals are not normally defined. If they are defined as Console specific logicals when Console Manager is started, then the associated actions will take place. Use the following command to define these logicals:
$DEFINE /TABLE=CONSOLE$LOGICAL_NAMES logical_from_table
Logical
Function
CONSOLE$NOT_TRUNCATE_LOGS
Disables truncation of logs being copied during archiving.
CONSOLE$NOVERIFY_DB
Disables database verification.
CONSOLE$MULTILINE_PROC_NUM
Enables definition of maximum number of created multiline windows (Default 3).
CONSOLE$DEBUG
Enables debug mode.
CONSOLE$ENS_WRITE_NOW
Enables appropriate write mode in ENS. If this logical was defined, this write mode completes synchronous I/O operation immediately without waiting for another process to read the mailbox message.
CONSOLE$ENS_WRITE_NORSWAIT
Enables appropriate write mode in ENS. If this logical was defined and if the mailbox is full, then synchronous I/O operation fails with a status Enter of SS$_MBFULL instead of placing the process in resource wait mode.
CONSOLE$QUEUEING_ENABLED
Enables queuing of the events occurred during archiving.
CONSOLE$NOEIGHTBIT
Enables terminal to use 7-bit ASCII code.
CONSOLE$PARITY
Enables set input parity. (ODD, EVEN, and NONE).
CONSOLE$FAIL_LISTEN_PORT
The port number used by a primary console manager to listen for poll requests from a secondary manager.
Default: 9999
CONSOLE$SSH_COMMAND
Provides the ability to set SSH command options and use the correct command for the IP stack installed on the system. For example, verbose mode can be turned on by defining the logical name, DEFINE/SYSTEM CONSOLE$SSH_COMMAND "ssh –v".
CONSOLE$SUSPECT_NODE_LIMIT
The number of failed or “suspect” polls for the secondary console manager to allow before taking control from the primary console manager.
Default: 4
