Using VAX 8500/8700/8800 Systems as Serviced Systems › Complete Tasks on the Host System › For VAX 8830/8840 Systems
Perform the following on the host system for each 8830/8840 system that you will be monitoring
- Enter the following command:
# cm -c node-name
where node-name is the name of the serviced system. Any keystrokes entered are forwarded to the VAXconsole MicroVAX II system.
- Press Enter to confirm that the communication path between the Console Manager host system and the VAXconsole MicroVAX II has been established successfully. The PS-HW-0> prompt is displayed.
- Enter the following command to share the same OPA0 device with the VAXconsole local terminal:
PS-HW-0> SET TERMINAL OPA0
- Enter the following command to enter the VAXconsole remote port into program I/O mode:
PS-HW-0> SET TERMINAL PROGRAM
- Press CTRL_G to Enter to the Console Manager host system.
Now all of the console functions to control the VAX 8830/8840 series system from a Console Manager software user interface can be performed, (however, enter these commands at the VAXconsole MicroVAX II terminal keyboard):
- EXIT
Copyright © 2010 CA.
