Previous Topic: Userdata as Specified in Filter DispatchNext Topic: Mail
Change the Eventsingle DECwindows Settings
You can change the DECwindows settings for Eventsingle as follows:
Modify DECW$XDEFAULTS.DAT in your DECW$USER_DEFAULTS directory (the default location for this is SYS$LOGIN) on the system where you want the window to appear. This is the userdata parameter in the dispatch entry.
The following table describes the DECwindows resources, default values and value ranges for you to customize the Eventsingle routine. For example, the entry for the Eventlist Background might be:
Console EventSingle.Background: Magenta
Note: DECwindows resources are case-sensitive, and there is a space character between “Console” and “EventSingle.”
DECwindows Resource
Default Value
Value Range
Console EventSingle.Foreground
White
Any valid DECwindows color
Black
Console EventSingle.PriorityCritical
Red
Console EventSingle.PriorityMajor
Magenta
Console EventSingle.PriorityMinor
Orange
Console EventSingle.PriorityWarning
Yellow
Console EventSingle.PriorityClear
Green
Console EventSingle.PriorityIndeterminate
Light blue
Console EventSingle.X
Center
”Center” or any valid screen pixel value
Console EventSingle.Y
Center
Console EventSingle.Width
800
Any valid screen pixel value
Console EventSingle.Height
200
Console EventSingle.DisplayNode
True
True or false
Console EventSingle.DisplayPriority
True
True or false
Console EventSingle.DisplayName
True
True or false
Console EventSingle.Font
Fixed
Any font valid for your server
Console EventSingle.DisplayText
True
True or false
Console EventSingle.Bell
26
Any value in the range 0 to 100
You must log out of your current session on the system where you want the window to appear and then log back in to activate your new DECwindows window settings.
