Previous Topic: Action DefinitionNext Topic: Change the Eventsingle DECwindows Settings
Userdata as Specified in Filter Dispatch
You must specify the following values, otherwise the routine will fail:
Value
Description
HOST
The DECwindows display you wish the window to appear on.
SERVER_NUM
The number of the server on the HOST display, normally 0.
SCREEN_NUM
The screen on which the window should appear. For single head workstations this is 0 and for dual head workstations it may be 0 or 1.
TRANSPORT
The DECwindows transport which your DECwindows client and server support. This routine supports TCP/IP, DECnet and LAT transports.
INTERVAL
The time for which the window will display on a remote workstation. After this period has expired the window will be closed. This parameter is optional. If specified it should take the form HH:MM:SS where HH is the number of hours to wait, MM the number of minutes and SS the number of seconds.
Separate all values by one or more spaces.
For example:
SALT 0 1 TCPIP 00:00:10
This shows that the window will close after ten seconds.
