Previous Topic: Change the Color of LabelsNext Topic: Change Audio/Visual Indicators for Event Notification
Change the Console Manager Display Background
You can change the color of the display background, and place an X11 bitmap on the background.
To change the Console Manager display background color
  1. Click the mode change button to change to Edit mode.
  2. Click the right mouse button on the display background, and choose Background... from the popup menu.
  3. Click the left mouse button on the Background Color field. This displays the Background dialog box.
  4. Select the color you require, then click OK.
  5. Click the mode change button to change back to Interactive mode.
  6. To save your changes, pull down the Options menu and choose the Save menu item to save the modified display.
