Previous Topic: Starting the Monitor Interface from the C3 InterfaceNext Topic: Getting Help on the Monitor Interface
The Monitor Initialization Command File
You can create a monitor initialization command file to run a sequence of monitor commands on startup. Put your commands in the file:
CONSOLE$USER_DEFAULTS:CONSOLE$MONITOR_INIT.DAT
or, if this logical name is not defined, put your commands in the file:
SYS$LOGIN:CONSOLE$MONITOR_INIT.DAT
See Chapter 9, “Customizing Console Manager” for more information on creating the initialization file.
