Previous Topic: Extracting Historical Log DataNext Topic: Invoking the Monitor Interface for a Serviced System
Logging On To a Serviced System
To log on to a serviced system
  1. Click the right mouse button on the system that you want to log into.
  2. Choose Login from the popup menu.
  3. Choose the connection type you want to use to perform the login.
If you want to log on using the command...
Then choose...
telnet
telnet
SET HOST
Set Host
rlogin
rlogin
  1. When the DECterm window appears, log on in the usual way.
The node name of the serviced system is appended to the end of the command before it is executed. The node name can be different from the system name defined in the configuration database. To specify the node names for your serviced systems, see Chapter 9, “Customizing Console Manager”.
The Login option uses the following logical names to determine the command that is to be executed:
You can change these logical names. For example, you could change CONSOLE$SETHOST_COMMAND to SET HOST/LOG.
To redefine these logical names copy the template file
SYS$STARTUP:CONSOLE$PRIVATE_SETUP.TEMPLATE
to
CONSOLE$PRIVATE_SETUP.COM
and edit it to reflect your individual requirements. The Console Manager startup procedure checks to see if
exists and executes it automatically.
