Previous Topic: Starting the Console Manager SoftwareNext Topic: Stopping the Console Manager Software
Restarting Console Manager at the C3 Interface
Unlike the command line interface, there is no restart command in the C3 interface. Instead, do the following:
  1. Pull down the Commands menu and choose the Console Manager submenu.
  2. From the Console Manager submenu, choose the Shutdown option. Then click yes to confirm shutdown. This enables the Startup option and changes the color of the two icons at the bottom of the main window to red.
  3. Repeat step 1, then choose the Startup option to start the Console Manager software. The color of the two icons at the bottom of the main window changes to green.
  4. If you are using ENS, and the Events window is displayed, you must reconnect Console Manager to ENS. To do this, pull down the File menu on the Events window, and select the Connect to ENS menu option. The Events window title changes.
