Previous Topic: Information on EventsNext Topic: Starting the Console Manager Software
Managing Console Manager from the C3 Interface
This section describes how to use the C3 interface to manage Console Manager.
Use the appropriate pull down menus for startup, shutdown, archive and reconfigure. If a menu item is grayed out, it means that you do not have the privileges to use it, or that the operation is not available due to the status of the running software.
To find out status information, the procedure is slightly different. See the section Finding the Status of Console Manager Components for a detailed explanation.
