Previous Topic: Console Manager Failover ConfigurationsNext Topic: Load Balancing with dedicated Fail over Console Manager.
Peer-to-Peer Loading Balancing with Fail over
In this configuration, the load is split between two Console Managers. Each Console Manager is defined as the secondary Console Manager for those serviced systems for which it is not a primary.
