Modifying the Configuration Database › Using the DECwindows Motif Interface to the Configuration Editor › Starting the Configuration Editor
Before starting the configuration editor
- Make sure that your DECwindows Motif transport is set up (see Appendix B, “Setting Up the DECwindows Motif Transport for the DECwindows Motif Interface.”)
- Ensure that the session manager security for the system you are setting the display from is enabled on your local workstation.
You can start the DECwindows Motif interface to the configuration editor from the command line interface (see Starting the Configuration Editor from the Command Line Interface) or the C3 interface (see Starting the Configuration Editor from the C3 Interface).
Copyright © 2010 CA.
