Modifying the Configuration Database › Using the Command Line Interface to the Configuration Editor › Leaving the Configuration Editor › Consequences of Saving With Verification Errors
If there are verification errors for a system, then the editor disables the system in the configuration database, warns you, and asks if you want to continue to exit. This has the following consequences:
- If you continue to exit, then the next time you attempt to start, or restart, the Console Manager software, the startup procedure will abort.
- You can reconfigure Console Manager, but you will be unable to connect to the console of the serviced system that has been disabled.
Copyright © 2010 CA.
