Previous Topic: Saving the Contents of the Configuration Database in Text FormatNext Topic: Importing the Contents of the Configuration Database
Exporting the Contents of the Configuration Database
To export the contents of the configuration database, enter:
CM Edit> export
Export filename (console_cfg.PORT): cfg_new.PORT
The example shown saves your database in the file cfg_new, and displays the text file on your screen for you to edit manually using the editor of your choice.
The configuration editor also lets you export the contents of the database to a text file for editing, and then import them back into the database. For example,
CM Edit> export new_db.PORT
