Previous Topic: The Configuration EditorNext Topic: Setting Up Your Configuration Database for the First Time
What You Can Do from the Configuration Editor
The configuration editor enables you to:
If you are using ENS, then you can also create and maintain the events, scans, filters and actions that are required for event notification. See Chapter 10, “Understanding ENS,” through Chapter 15 “Creating Your Own Action Routines.”
Note: Entries in the configuration database may have mixed case names. All Console Manager commands which expect a name perform case-insensitive comparisons.
