Previous Topic: Connect Using TELNET TransportNext Topic: Configure for TELNET
Setting up a TELNET Connection
To set up a connection using a terminal or console server with the TELNET protocol
  1. Install the terminal or console server using the documentation provided with the terminal server.
  2. Connect one end of the cable to an unused port on the terminal or console server, using a DECconnect adapter where necessary.
  3. Connect the other end of the cable to the console port of the serviced system, using an adapter where necessary.
