This guide is intended for users who want to:
The following table shows you where the tasks you wish to complete are described, and the type of experience you should have before attempting any of them:
Task |
Required Experience |
See the chapter |
Setting up and managing Console Manager on the host system. |
System management, and at least a working knowledge of the operating system. |
Introduction through Managing Console Manager the appendix Using VAX 8500/8700/8800 Systems as Serviced Systems.” |
Monitoring events on the systems being managed by Console Manager (the serviced systems), and performing system management tasks on those systems. |
System management of a serviced system. |
Introduction and Using Console Manager From the C3 Interface, if using workstations; Introduction and Using Console Manager From the Command Line Interface if using character cell terminals. |
Writing event notification action routines additional to those supplied with Console Manager. |
High level language, shell programming, or writing DCL command procedures. |
Copyright © 2010 CA.
