The CA NSM SCOM Integration converts SCOM alerts to Event messages. The actual SCOM alerts are not displayed verbatim on the Console.
Note: You can see the actual SCOM alerts in the SCOM Alerts Viewer of the Management Command Center.
The following table shows what information from SCOM alerts is put into Event messages:
SCOM Alert |
Event Message |
SCOM server that generated the alert |
Node |
Process that gathers SCOM alerts |
User |
SCOM object where the event that caused the alert occurred |
CAOPS prefix |
Message ID |
SCOM alert description field |
Message Text |
GUID (Globally Unique Identifier) |
User Data |
SCOM object display name |
Category |
The following table shows how SCOM alert severity is converted to Event severity:
SCOM Alert Severity |
Event Message Severity |
Success |
S (Success) |
Information |
I (Information) |
Warning |
W (Warning) |
Uninitialized |
U (Unknown) |
Error |
F (Fatal) |
Note: Event Management does not communicate directly with SCOM.
Copyright © 2010 CA.
