Previous Topic: Multiple Monitor SupportNext Topic: Start a Remote Control Session
Wake-on-LAN Support
Remote Control lets you use Wake-on-LAN (WOL) functionality to power up and connect to remote host computers that are not switched on, for example, the computers that are located in different time zones. You can wake up a single PC, start it, and control it from the Remote Control viewer.
The WOL feature in the Remote Control viewer is available only for computers in the global address book, and only if the Client Automation administrator has permitted it.
Note: For detailed information about WOL functionality in the DSM Explorer and Remote Control, see the DSM Explorer Help and the Remote Control Administration Guide.
More information:
Specify Advanced Options
Remote Control Viewer
