Previous Topic: Contact CA TechnologiesNext Topic: Using Folder Options
Remote Control Viewer
Remote Control, designed for centralized enterprise management. The Remote Control viewer lets you access remote services such as network applications, transfer files among domain managers and workstations, and take control of distributed desktops. After the product is installed, use one of the following methods to access the viewer:
Note: You can also launch a web version of the viewer, the RC Web Viewer interface, by double-clicking RCViewer.html located in the Program Files\CA\DSM\bin folder.
