Remote Control Viewer › File Transfer Feature › Set the Maximum Bandwidth
You can set the maximum bandwidth that is used to transfer files, establish remote control connections, or record sessions.
- Right-click a computer name in the Global or Local Address Book pane and click Open.
- Click the Advanced tab.
- Select the maximum bandwidth from the Bandwidth Limiter drop-down list of options.
Note: Unlimited is the default maximum.
- Click OK.
The maximum bandwidth is set.
More information:
Connection Settings Dialog
