Previous Topic: Control Connection Speed and Set Visual EffectsNext Topic: Specify Advanced Options
Set Viewer Session Options
Use the Viewer tab to set the viewer’s remote control session behavior at the start of the connection. The options set here can be modified during the session using the toolbar or the Active Sessions context menu options.
Note: Changes made on this tab only apply during the current session and are lost if the session is removed.
  1. Select the display options.
  2. (Optional) Specify that the session is to be recorded to a specified recording file upon connection.
    Note: The default setting is False.
  3. Enter the file name used for the recording in the Recorded Session File field.
    Click Browse to invoke the File Save dialog, letting you specify a recording file name.
    Default: A default name is automatically generated, based on the default recording path, computer name, and current date and time.
  4. Click Connect.
    Remote Control attempts to connect you to the host computer after all fields in the dialog are completed.
    Note: The Help button is not available when you use the RC Viewer Web Interface.
