Remote Control Viewer › Viewer Pane › Address Books › Add a New Computer to the Address Book
You can add new computers to your local address book.
- Right-click the Local Address Book node and click New, Computer.
Or select New Computer from the Tasks portlet of the Local Address Book pane.
- Enter the name and description of the computer you want to add in the Name tab.
- (Optional) In the User Information tab, enter the user name and password of the computer you want to use when connecting to this computer.
Note: See the Information field for information about entering the user name and password.
- Click Add in the Connection tab.
- Choose a protocol type from the drop-down list and enter the computer name or IP address of the computer to which you are attempting to connecting.
Note: See the Information field for tips about entering the protocol and address.
Click OK and then OK.
The computer information is saved and added to the address book.
