Remote Control Viewer › Viewer Pane › Address Books › Modify Computers in an Address Book
You modify your local address book by moving computers in and out of it; you can also change properties of a computer in the address book.
- From the DSM Remote Control tree or the Viewer pane, click Local Address Book to see the list of computers in your address book.
- Right-click the computer whose properties you want to modify and click Properties.
Note: You can modify fields in one or more tabs as needed.
- Modify the name and description of the computer in the Name tab by clicking the field and modifying the information.
- Modify the user name and password in the User Information tab by clicking the field and modifying the information.
Note: For more information about entering the user name and password, see the Information field.
- Click Modify in the Connection tab.
The Protocol/Address dialog appears.
- Modify the network protocol by selecting the type from the Protocol drop-down list and entering a different IP address or computer name.
- (Optional) Change the order of the connection address in the list by using the Up and Down arrow buttons.
- Click OK.
The new properties of the computer are saved.
