Remote Control Viewer › Viewer Pane › Viewer Properties Dialog › Configure TCP Options
Use the TCP tab to set up Internet Protocol (TCP/IP) connections.
- Right-click the Viewer node and select Properties.
- Select the TCP tab.
- In the Connection Time Out field, enter the number of seconds after which a connection attempt times out and a connection cannot be established. The default setting is 10 seconds.
- In the Port field, enter the protocol port that Remote Control uses for communication.
This value must be the same as that of the remote computer to which you are connected.
Note: Check with your system administrator when establishing connections through firewalls and proxy servers.
Default: 4728
- Click OK.
Your TCP configuration options are saved.
